layer management
layer management
i received this message from a friend
i was asking what was wrong with my config.pro bc it had duplicated mapkeys 15 times inside
but the last thing he said was
Also, def_layer is the old school of thinking in layer management. I suggest that you setup layer rules in your start parts and get rid of the def_layers.
so my question to all of you is what is your company standards or your personal settings
this is whats in my config.pro
def_layer LAYER_AXIS axis
def_layer LAYER_SURFACE surface
def_layer LAYER_DATUM datum
def_layer LAYER_POINT points
def_layer LAYER_CURVE curve
def_layer LAYER_CSYS csys
def_layer LAYER_QUILT quilt
RE: layer management
Here is a great thread on layers thread554-137512 if you need more do a search on this forum. Best of luck
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
I'm using WF 2 and am getting the same thing; I keep getting multiple definitions of the same mapkey in my config.pro. Essentially, the Delete, Modify, Update functionality in the mapkey utility seems to be dysfunctional.
Tunalover
