Curved plywood sill/top plates
Working on a 20'x40' oval (in plan) structure. The framer used 1 1/8" rated plywood for the curved sill plate, and double 1 1/8" for the top plates. Is this typical practice for curved situations? This is the first curved structure I have worked on.
Also, how are curved shear walls dealt with? They cut a 1/8" deep vertical cut all the way up the wall every 4 or 5 inches O.C. so they could bend the plywood to fit the wall. Obviously, this is no good. What is the norm? What do you suggest for a fix?
Thanks!
Thanks!
RE: Curved plywood sill/top plates
Where the plywood is cut, can you use the thickness of the plywood minus the cut depth for your "effective" thickness of shearwall?
The effective thickness would be slightly less than 1/4".
The shear in the walls is minor, and I'm not worried about it, but I would like to have at least the 3/8" thickness. I think I will have them put a 1/4" or a notched 3/8" panel on the outside of the ex. panel. That should take care of it.
For the sheathing, I have usually seen 1/4" plywood used, since it is flexible enough to curve.
DaveAtkins
