Moment of Inertia of screw drive.
Can anyone help me calculate the polar moment of inertia of a screw based transmission shaft?  I'm trying to calculate the size of the screw I will need to transmit a certain amount of power.  Thanks
RE: Moment of Inertia of screw drive.
Polar moment of inertia for a shaft is equal to twice the moment of inertia, or 0.098 D^4.
But because it is a screw, the diameter is different depending on where I take the cross section.  Doesn't that make a difference?  Which diameter do I take?
The smallest one.
Yes, that is very useful, thank you.
