Adding holes with holde wizard very slow.
When ever I add holes using the hole wizard they take a very long time to put in. The hole wizard feature pops up quickly then I go pick the holes I want, use the position tab to locate the holes, then when I click the check mark to accept, it takes like 30 seconds to a minute of just sitting there before it pops the holes in, even if it's just one hole. I am running 2006 service pack 2, does anyone else have this problem?
RE: Adding holes with holde wizard very slow.
What are you PC Specs?
What Video card and version of drivers are you using?
How many holes are you placing into the part using the Hole Wizard?
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
pc specs are 3.6ghz 2gb ram.. 3d labs realizm 100 256mb viddo, it's a brand new machine. Video card is running the drivers off the solidworks site. This happens even if you are placing only one hole in a part, even the in very simple parts.
Flores
SW06 SP2.0
Crashj "hey, d:, wake up!"
Hardie "Crashj" Johnson
SW 2005 SP 4.0 (reluctant to change)
Matrox Millenium G550
AMD Athalon 1.8 GHz 512 Meg RAM
I have found that if the default.mdb file is not located in the folder you point to it will take a long time to upload.
