Short circuit data & motor starting, protective relay
I am doing a s-c study. The only data I got from Utility are initial fault (the fault available now) and ultimate fault value( the fault after the future expansion).
My questions are,
1.Can I use initial fault as Min fault contribution to conduct motor starting and protective relay study? Or I should ask for the Min and Max data available for now before expansion?
2. I am assuming that we should use ultimate fault value to conduct the max fault study and rate the equipment. Is that right?
I am new to North America. I look forward to being aware of the common practices here in order to do a good job.
Thank you guys in advance.
My questions are,
RE: Short circuit data & motor starting, protective relay
