delta to wye problem
hello connecting 112.5 kva transformer delta 480V primary and wye secondery 208V voltage between tubing (ground) and w is _135 V y is 237V and e is 330V .connecting 60kva transformer voltage is 0 V. How to explaine that? Can I connect X0 and ground to eliminate that "problem" thanks
RE: delta to wye problem
The X0 should always be grounded. Connected to the enclosure and also to building steel or other designated grounding electrode.
Ground x0 to the enclosure and also to the buildnig steel/grounding electrode.
Your 60kVA x0 may already be bonded to the enclosure.
