Structural Analysis of Dynamic Wind Load on Wind Turbines
Is there a general guideline for analysis of dynamic wind loads on wind turbines (specifically for wind-power generation)?
(1) Would the frontal wind area of the rotor decrease or increase as the result of the blades rotating? More simply, even, would the frontal wind area under consideration be taken as the area of a stationary rotor, or some function of the entire sweep area?
(2) For a very large wind turbine, roughly 100 metric tonnes in weight, would the centripedal forced caused by the movement of the rotor induce significant 2nd order effects on the tower mast and foundation?
RE: Structural Analysis of Dynamic Wind Load on Wind Turbines
Bring back the HP-15
www.hp15c.org
As to the magnitude of different effects, you'd have to design and see. And come to think of it, a wind load ought to create a crosswise moment in the tower, which would vary depending on the power output.
I can foresee a whole host of related problems- wind loading, vibration, designing for a wide range of wind speeds AND a wide range of rotor speeds, shifts in wind direction, ice buildup, fatigue, etc.
