question about footings
The actual design footings for a three floor building calls for 2ft deep footing with reinforcement at 1 ft -10" from top.
The bearing rock is about 6ft from required elevation. the contractor wants to fill the footing pit with 6ft of concrete(4000psi) with the reinforcement provided at 1ft-10in from top. Is this an acceptable practice?
RE: question about footings
www.SlideRuleEra.net
