minimum temperature of A106 piping
Table 323.2.2A in B31.3 shows that A106 CS Pipe minimum temp to -20F is only good to a certain wall thickness. As the wall thickness increases the allowable temp gets warmer.
Is this dependant on coincidental pressure and can deviations be allowed for short periods of time.
RE: minimum temperature of A106 piping
Your answer lies in the provisions of clause 323.2.2.  Work your scenario through and see what drops out.
Steve Jones
http://www.pdo.co.om/pdo/
