Cylinder Requalifictions facility to be constructed
I need urgent help, where can i find a company that specializes manufacturing and processing solutions specifically for establishment of LPG cylinder requalification plant of facility? I searched the net for any existence of such company, i only found a few, but the their locations are very far from where i am. I was lookng for any engineering or construction company that can be able to help me that is within Asia.
thanks.
thanks.
RE: Cylinder Requalifictions facility to be constructed
The processes included are:
Shroud and footring straightening.
Internal cleaning.
Pressure testing.
Shotblasting.
Painting (Powder or Wet paint).
Internal inspection.
Valve on screwing.
Tare weighing.
Tare marking.
Leak testing after valve on screwing
Hot works
1. Foot ring and shroud (Handle) cutting machine
2. Foot ring and shroud welding machine
3. Annealing furnace
Am looking for a company that could provide me a complete solution for the investment. There is 1 company I found but it is not located within Asia..thus it would be more expensive. :(
try this company - it seems it is based in india and they also can help you if you contact them:
http://www.lpgforyou.com/index.htm
