CX-Programmer V6.00 can't close the program? Help!
When I try to close the program this message commes up.
[O table (special units setups)cannot be closed because it is being processed. Press Ok after closing the IO table and the edit parameters dialog.]
But I don't have these windows openned.
Note that in my project I have 2 plc's. I can open the IO table of the first cpu but cannot open the one for the second cpu.
Somehow I think it's opened but i can't see it. Might be running in the back ground. I haven't opened it at all during my session.?
How can I fix this problem?
Ray
Ray
RE: CX-Programmer V6.00 can't close the program? Help!
Seems to be something with updates to Windows XP. Never had it before.
I normally shut it down (when it happens) with ctrl/alt/del. Open CX-Programmer again and all is well.
Do not understand your problem with the second PLC though. Have you looked in "Windows" at the top of the page to see if it is there?
