table driven spline
table driven spline
table driven spline
Is there a way in V5 to import coordinates from a table like excel and automatically generate the 3D spline?
RE: table driven spline
It comes with your software... Check your computer for a file called "GSD_PointSplineLoftFromExcel.xls"
Check out CATBlog!
Why don't you search the forum for 'point excel' ???????
Eric N.
Refine your search to "catia points excel", otherwise it will mean trawling through loads of non-Catia threads.
It only works from Release 9 and upwards, although R12 did have problems with it, which have now been resolved.
for those who are not using R15 you can find a corected version of the online doc Excel file on www.catiav5forum.com
this version can work with inch or mm
Eric N.
