Need help to start and run ansys 10 after installation.
I used Ansys 9 a lot before, and I am trying to model a FSI problem with Ansys 10 since it is better for FSI.   But after installation of Ansys 10, when I run Ansys, the following error pops up:  "Error execting Ansys.  Refer to system-related error messages in the ansys online help.  If this was a distributed ansys job, verify that MPICH or MPI/Pro was installed correctly and is in your PATH, check your environment steeints or check for invalid command line option."
I am sure that the ANSYS FLEXlm License Manager works fine.  I think it might be related to enviroment setting, but just do not know how to fix it.  If you could give me any suggestions or comment, I highly appreciate it!  Thanks!.
