Question.
Question.
If you use a pure magnesium with stainless steel will it react chemically? Are there any safety warnings with these substances?
RE: Question.
First step is to visit the suppliers web site for a safety data sheet.
This should provide sufficient indication of the hazards to prompt a further ivestigation of material compatability.
Web searches will usually provide a wealth of information.
JMW
www.ViscoAnalyser.com
RE: Question.
We use stainless reactors do do reactions with 99.95% pure magnesium. The problem is that the magnesium scrapes the stainless and you tend to get ppm levels of iron in the solution.
Does that help?
Stonecold
RE: Question.
cold or hot, presence of other chemicals etc. ? Otherwise
what kind of reaction can there be between Mg only ?
( "between" implies more than one )
<nbucska@pc33peripherals.com> omit 33 Use subj: ENG-TIPS
Plesae read FAQ240-1032
