hot water generation
Where can I find hot water generation guides (not steam).
Application: central hot water system for large buildng.
It will be a electrical system
RE: hot water generation
Whether it's for domestic hot water or building heating, once you know how many BTU/hr the system needs, all the individual bits can be selected. ASHRAE will have tons of info, as will manfacturers of the various components.
yes electric geysers.
What ASHRAE code specific?
BTU/hr (boiler output) = GPM X 500 X delta-T
Then you would just flip the BTU into kW for electric boiler output. They're almost 100% eff, so input & output will be nearly the same.
