[b]Can anybody provide an Harmonic analysis example in ansys[/b]
hi frnds,
i am requesting you all to provide harmonic analysis examples.....nd..any documents or info also nice to have from you...
thanks in advance...
krishi..
RE: [b]Can anybody provide an Harmonic analysis example in ansys[/b]
I am requesting you to look at the ANSYS help file which contains much good information and several examples. I recommend that you also read the introduction to harmonic analysis (also in the help file) before you do the examples.
See FAQ569-1083 for details on how to make best use of Eng-Tips.com
Thanks Drej,
thanks for ur suggestion. I have already gone through those tutorials..and i am just trying to find out as many examples as i can...thatz y i requested all people. Anyhow..itz nice to c ur reply...hope i will get some more..
regards,
krishi
hi EricZaho,
thanx for all your links..i hve gone through them..and got most information...thanx again..If you would like to give any suggestions regarding my model in ANSYS, glad to receive.
regards,
krishi
If you have difficulties in your analysis, describe it in details. We might be able to throw out some hints.
Hi EricZhao,
for me the exact problem is to get the idea in modelling(pre processor), i.e which kind of model(for the cutter) i need to take to mesh it. Is it a 3D CAD model or any other way.If i will take 3D CAD model, the elements will b really lot and because of this we all know the results quality. Thaz y i am thinking how do i solve this problem. Here exactly i need to have some suggestion. If possible give me the idea to model the milling cutter(4 inserts) and work piece in ANSYS. That will solve my problem.
Thank you,
Krishi
