Raised Text on Loft
Raised Text on Loft
Raised Text on Loft
We are having a problem with raising text from a loft.  I've used the wrap feature, but unfortunately this can only be used on a cylinder, cone, etc... but not a loft.  Does anyone have any workarounds??
RE: Raised Text on Loft
you could possibly create text on a plane & then extrude it to the loft surface, then, create a sketch perp. to the text and cut it along the surface's profile....never tried before....hope u have luck with it!
1) Offset surface
2) Extrude text from plane up to original surface
3) Cut text from plane up to offset surface
Great thanks that worked.
That's what I normally do.  You can get more ellaborate with surfaces in some cases where necessary to create a surface to cut with.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
