Oddball Metric Threads
  I'm a QC Tech for a Communications Equipment Assembly plant here in Connecticut.
  Today I had a visit from a Toolmaker, asking me for the tolerance range on an M29 x 1.5 thread.
  Wouldn't ya know the Machinists Handbook skips right over the M29's!
  I know the "29" represents 29mm Nominal, and the 1.5 represents the threads per revolution, but I can't come up with the tolerance ranges for the Major and Minor threads to save my life!!
  Anyone know what the tolerance range is?
        -Soupy1957
RE: Oddball Metric Threads
Hi soupy1957,
The 1.5 indicates the pitch of the thread, i.e. the linear distance between adjacent crests. M29 is a damned peculiar thread - not one of the standard ranges.
The following link might help you - I use it as a quick guide when there are no mechies to ask.
http://www.boltscience.com/pages/screw1.htm
The other link has some discussion of standard tolerancing
http://euler9.tripod.com/bolt-database/22.html
It lists
Quote:
Default metric fastener thread tolerance class.  If thread tolerance class designation (e.g., "-6g") is omitted (e.g., M10 x 1.5), it specifies "medium" thread tolerance, which is 6H/6g.  The 6H/6g fit is the standard ISO tolerance class for general use.
One day my ship will come in.
But with my luck, I'll be at the airport!
