Shaking Animation
Shaking Animation
When running an animation with the perspective view enabled it shakes. When dragging along the timeline the assembly doesn't shake, also when the perspective view is disabled the shaking goes away. Is there a fix for this?
RE: Shaking Animation
Did you keep your views locked while creating the control points in your animation? If not, this could mean your views changee a tad between frames.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
