heat loss through pipe
What formula can be used to determine the heatloss of a pipe insulated with a certain material?
RE: heat loss through pipe
Few pipeline problems seem to require that sort of rigor, but since I needed to know condensation performance of a warm 100% RH gas as it cooled to ground temperature in a decreasing-pressure environment then I don't know what steps I could have skipped. That was before the days of cheep FEA.
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
The harder I work, the luckier I seem
"Calculate the thermal performance of both insulated and uninsulated piping, ducts and equipment,
Translate Btu losses into actual dollars,
Calculate greenhouse gas emission and reductions,
et., etc."
http://www.pipeinsulation.org/
thks
