Cutting Polyurethane
We have 1" thick PU plates with approx a 1/16" to 1/8" metal plate in them.  What is the easiest way to cut this.  Can we use a cutter/grinder that we would use for metal?  Or is there another/better way?
RE: Cutting Polyurethane
Band saw.
Grinder will likely result in a sticky mess.
The original manufacture would be the best source as they probably cut it and reference it everyday.
_______________________________________
Feeling frisky.........
www.tailofthedragon.com
If you have a lot of them, consider water jet.
We cut up to 100 mm PU plates with steel backplating with a bandsaw
Try it and succes
Polleke
