Hoesch Membrane Filter Press Efficiency
Background: Fermentation process upstream yields extracellular product. Cool, add solvent, add filter aid, filter on MFP, wash cake with solvent (0.5 volume of feed) send filtrate to 2 stage evaporator, recover solvent in distillation column. send concentrate off evap to tank, heat, settle, decant bottoms to drain, top is product.
After solvent wash of MFP, cake is water washed (0.5 volume of feed) and squeezed with this filtrate skipping evap going straight to distillation column to recover solvent.
I am concerned about product loss in water wash / squeeze filtrate or in the cake.
Question? Is a 1:2 solvent wash / feed ratio common or is it backwards? I would think you would want to wash with more volume. What are some fundamental ideas about this ratio?
RE: Hoesch Membrane Filter Press Efficiency
