Inverted Taper Pressure Balanced Lubricated
what does Inverted Taper Pressure Balanced Lubricated valve mean
always i see this on a plug valve spec.
best regards
best regards
RE: Inverted Taper Pressure Balanced Lubricated
Maybe this link will work. If not, go to FLowserve.com, valves, and Nordstrom.
http:
Lubricated plug valves are used in refining, water and waste, and mining applications.
There are also NONlubricated plug valves. These have a tapered plug that nests into a (usually) tfe sleeve/liner in the body. These tend to be more useful in chemical applications. These are also in the Flowserve.com website under "Durco".
