Diesel Tachometer
Diesel Tachometer
Diesel Tachometer
My Dad has a Diesel tractor and he wants me to build him a tachometer for it.  He doesn't want any digital electronics on it.  What would be the best way to generate a pulse off of the flywheel to use with a regular tachometer?
RE: Diesel Tachometer
A straightforward solution is to use the National Semiconductor LM2917 chip which is designed for this application.
http://www.national.com/pf/LM/LM2917.html
It is compatible with an inductive pickup that you can position close to bolt holes on the flywheel.  The pickups have a coil and a magnet so will detect a passing magent, a metal object or a hole.
