DB Works question (should be simple)
I have moved a SW drawing from one directory to another. Now when I try to open the drawing, the preview window in DBWorks states that the file does not exist. This is correct, it no longer exists (in that location). How do I edit the path to the new location? I thought this would be a simple task. Maybe there is an "Update Path" button that I do not see.
Drake
Drake
When it comes to protecting yourself or your family it is better to be judged by 12 than carried by 6.
RE: DB Works question (should be simple)
Solidworks Explorer or Windows Explorer or DB Works or ???
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
SolidWorks & DBWorks would not know that you have moved/renamed a file if you didn't use them to move it & update the references.
Thanks and I hope this may help someone else in the future,
Drake M.
www.taylordyno.com
Have you used other PDM systems?
DBWorks allows you to rename a document and/or to move it to another directory or disk while keeping all the existing relations
Ed Hulse
Sr. Designer/DBWorks Admin
Drake
Do not use Win Explorer OR SolidWorks Explorer.
For users who are not DBWorks admins, "open for updating" should be disabled.
Drake
If you do, administrators should have Admin tools installed with DBWorks (but not regular users). One of these tools is DBWarm.exe which is the Access Rights Manager. This allows the admin to assign users to groups and decide what rights each group has.
Most of our users are in a group called Designer and this group is denied the right for "Open for updating"
Drake M.
www.taylordyno.com
This will take it off the menu and keep you from getting in there accidentally.
