Bearings with term CN
Customer insisting on using anti friction bearing for AC motor with CN type ( Could be CM )I know nearly all motors have bearings with C3 fit. What do you think he may be reffering to
RE: Bearings with term CN
CN is a "normal fit" bearing, somewhere between a C2 and a C3 fit.
Raisinbran
Hello Magneticted,
You could find the two terms: CN and CM.
And both refers to the internal bearingĀ“s clearance. this is the space providede the elements for a thermel expansion and  grease film in order to avoid and prevent early bearings failures due to preloading.
The clearance are specified as C0,C2,C3,C4 and you could find some special manufacturers with C5.
CN is normal bearing clearance and is between C2 and C3 range,the tolerance of thermal effects is high whe the clearance is higher. The lower clearance are necessaries when you must be restric Vibration and noise.
CM Clearance is specified in some manufacturers designs where  internal clearance help to reduce the noise.
Petronila
