Text Styles Refuse to Go Away
I've got a drawing that I use as a template to start other drawings. Somehow through the ages, it has gotten a dozen text styles on it that I can't delete. I can delete everything in the drawing, delete xrefs, blocks, dim styles, etc., but those dozen text styles are still there. If I try to purge, they can't be purged. If I click on them and try to delete, it will say "text style in use" and can't be deleted. Any ideas?
RE: Text Styles Refuse to Go Away
try htt
L.
ADT 2004
ACAD 2002
I DO get a message that says "1 was not in current space". Dunno what that means. I've erased everything in paper space and in model space. Hitting "select all" doesn't select anything.
Exxit- looks like the product I need, although, why that capability isn't built into a $$$$$ software in the first place is beyond me.
