creating a filled section in a 2d drawing file
I'm using wildfire 2.0. I'm trying to create a 2d filled section. I'm  drawing a piping diagram in detailing mode. I 'm using detailing mode as a 2d sketcher. I need to create a filled section of a triangle. Thanks for any help
RE: creating a filled section in a 2d drawing file
If you have sketched the triangle in Drawing mode, select its three sides and use Edit-->Fill-->Solid. The sides need to form a closed loop at their endpoints. Under Sketch-->Sketcher preferences, there are some options that might make drawing the triangle easier.
If you have to make a lot of these, make it as a drawing symbol.
thanks it worked
