CO2 fragilizes steel used in beverage bottles ?
hi folks, any comment or literature reference would be appreciable.
I would like to know if the CO2 inside the Beer bottles or any other gaseous beverage can diffuse and fragilize the steel, even under very long exposures. I am talking about steel bottles either made by welding or deep drawing.
Thank you for your time,
Maleck
Maleck
RE: CO2 fragilizes steel used in beverage bottles ?
Maleck
Cory
Maleck
Hg
Eng-Tips policies: FAQ731-376
Hg embrittles aluminum. Better drink quickly.
Ken
In the USA, the majority of beverage containers are manufactured from Al alloys. However, outside the USA, it is about 50 % Al and 50 % steel.
Cory
LewTam Inc.
Petrophysicist, Leading Hand, Natural Horseman, Prickle Farmer, Crack Shot, Venerable Yogi.
Ken
I worked for a can manufacturer - steel cans are produced in large quantities.
Ken,
Yes, all beverage cans are coated internally. Typically, it is an acrylic-epoxy blend.
Cory
I would not worry about "fragilizing" of your steel cans due to the presence of CO2 due to diffusion of CO2 into the steel. I would be thinking more along the lines of corrosion due to the acidic liquid inside the can.
A multivariable analysis approach was used in the following study:
"A Neural Network Model for CO2 Corrosion of Carbon Steel" by Srdjan Nesic and Miran Vrhovac, J. Corros. Sci. Engr., vol 1 (18 March 1999): http://www.jcse.org/Volume1/paper6/v1p6.html
The corrosion reactions and the models & experimental results of others are given. The only accurate models are for the laboratory case of bare steel corroding in pure CO2 saturated water ("worst-case" corrosion). But reality is more complicated owing to factors such as
formation of protective surface films,
presence of the hydrocarbon phase,
presence of corrosion inhibitors,
presence of glycol or methanol,
condensation in wet gas transport,
multi-phase flow,
steel type,
corrosion history, etc.
This study's artificial intelligence model gives a better data fit than the other models.
Selected References:
1. C. de Waard and D. E. Milliams, "Prediction of Carbonic Acid Corrosion in Natural Gas Pipelines", First International Conference on the Internal and External Corrosion of Pipes, paper F1, University of Durham, UK, 1975.
2. L. G. S. Gray, B. G. Anderson, M. J. Danysh, P. G. Tremaine, "Mechanism of Carbon Steel Corrosion in Brines Containing Dissolved Carbon Dioxide at pH 4", Corrosion/89, paper no. 464, (Houston, TX: NACE International, 1989).
3. S. Nesic, J. Postlethwaite and S. Olsen, "An Electrochemical Model for Prediction of CO2 Corrosion", Corrosion/95, paper no. 131, (Houston, TX: NACE International, 1995)
4. C. de Waard and U. Lotz, "Prediction of CO2 Corrosion of Carbon Steel", Corrosion/93, paper no. 69, (Houston, TX: NACE International, 1993).
5. A. Dugstad, L. Lunde and K. Videm "Parametric Study of CO2 Corrosion of Carbon Steel", Corrosion/94, paper no. 14, (Houston, TX: NACE International, 1994).
6. A. K. Sheikh, J. K. Boah and D. A. Hansen, Corrosion, 46 (1990) p. 190.
7. J. W. Provan and E. S. Rodriguez III, Corrosion 45 (1989) p. 178.
8. C. D. Adams, J. D. Garber, F. H. Walters, C. Singh, "Verification of Computer Modelled Tubing Life Predictions by Field Data", Corrosion/93, paper no. 82, (Houston, TX: NACE International, 1993).
9. C. de Waard and D. E. Milliams, Corrosion, 31 (1975): p.131.
10. G. Schmitt and B. Rothman, Werkstoffe und Korrosion, 28 (1977): p.816.
11. J. O .M. Bockris, D. Drazic and A. R. Despic, Electrochimica Acta, 4 (1961): p.325.
12. S. Nesic, N. Thevenot, and J.L.Crolet, "Electrochemical Properties of Iron Dissolution in CO2 solutions - basics revisited", Corrosion/96, paper no. 3, (Houston, TX: NACE International, 1996).
13. M. R. Bonis and J. L. Crolet, "Basics of the Prediction of the Risks of CO2 Corrosion in Oil and Gas Wells", Corrosion/89, paper no. 466, (Houston, TX: NACE International, 1989).
14. L. G. S. Gray, B. G. Anderson, M. J. Danysh and P. R. Tremaine, "Effect of pH and Temperature on the Mechanism of Carbon Steel Corrosion by Aqueous Carbon Dioxide", Corrosion/90, paper no. 40, (Houston, TX: NACE International, 1990).
21. C. de Waard, U. Lotz and A. Dugstad, "Influence of Liquid Flow Velocity on CO2 Corrosion a Semi-Empirical Model", Corrosion/95, paper no. 128, (Houston, TX: NACE International, 1995).
