Mate Errors with Assembly Level Cut-Extrude
Hi all,
I am doing a section view of a Tank with Transducers.I did assy level pattern of the transducers. I have two configurations:one with an Assy level cut-extrude to generate the section view and other in which the Assy cut is suppressed. It worked great.
Now I changed the number of instances in the linear pattern. Edited the feature scope of the Assy Cut and included the newly created Instances of the Pattern. It Cut the patterns well but its generatiing mate errors. When I am toggling to the other configuration ( where Assy cut is suppressed), mates are resolved properly.
If I delete the Assy cut and redo it everything is fine. Any help will be appreciated.
RE: Mate Errors with Assembly Level Cut-Extrude
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Windows 2000 Professional / Microsoft Intellimouse Explorer
SolidWorks 2006 SP01.0 / SpaceBall 4000 FLX
Diet Coke with Lime / Dark Chocolate
Lava Lamp
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
