Hyperlinks - Opening parts in SW
I have a small 'web-site' that I have hyperlinks linking to various SW files (both parts and assemblies).
The issue I am having is that the hyperlink opens up the SW file in a new IE window. The feature tree is still there, and it looks like SW (minus the toolbars and menus), but its just IE.
How can I make the hyperlink open the files in SW, and not IE?
Thanks in advance,
Thanks in advance,
phreaq
Has anyone seen my brain today? (^_^)
www.phreaq.net
RE: Hyperlinks - Opening parts in SW
What I am thinking is you can't open a file using SW when you are opening it over the web so IE launchs SW within the IE window. If you don't want IE to open it with SW embedded. THen you hhave but 2 choices:
Change the file to a *.zip instead of a direct SW file.
Or
RMB the link and do a "Save as"
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
