White Text on start-up
We have found that in SW2006 SP1 when you first open a drawing, your text goes white. We can get it back to normal but we have to closethe drawing then reopen it.
"Perfection - a result of many mistakes."
BJH
RE: White Text on start-up
Can't stress this enough out here, but I do it here on a daily basis:
Make sure you are using a supported card and drivers.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
BJH
Presuming you've got the HP driver on CD or something so that you can go back, you should definitely try the driver from the SWX site.
When talking "SWX supported" you can't separate the card from the driver.
Bring back the HP-15
www.hp15c.org
ht
Be sure you uninstall the old driver, reboot, install the new driver, reboot, and test again.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
