Efficiency of the separator
Hi All,
What's the meaning of efficiency of the separator?
Thank you.
regards,
oilgas80
Thank you.
regards,
oilgas80
Efficiency of the separatorEfficiency of the separator(OP)
Hi All,
What's the meaning of efficiency of the separator? Thank you. regards, oilgas80 Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Efficiency of the separator
Hope that helps.
Efficiency on separation of liquid-gas phases (assuming that's what is being referred to) can also be based on the liquid "particle size" removed (or "separated") from the gaseous mixture.
But that all depends on what the original phrase was meant to mean or how it is defined for that specific write-up.
Based on the amount of data and information given, the answer is: nobody really knows or can tell. A lot of people will guess and contribute some wild ideas; but the net result is that more information is needed.
I appologies for my mistake.
This is basically a Horizontal 3 phase separator. It's 48" X 10' S/S.
The question i received from my collegue is how to calculate the efficiency of the separator at 50bar/1.5 million cubic meter gas capacity?
Hope now i posted the question correctly.
Thank you.
regards,
oilgas80
There’s nothing to apologize to me for. I believe I understood the nature of your question and I tried to answer it appropriately. As a ChemE, I’ve been fortunate in working around the petroleum production arena in several manners. I’ve worked for companies who designed and fabricated 3-phase oil-gas separators. The name, 3-phase, is a misnomer I believe, because only 2-phases are involved: an oil+water liquid phase mixture and a hydrocarbon gaseous phase. Nevertheless, that’s what they’re known as. I’ve also done process design around the production coming out of such vessels. I’ve never designed them and I don’t believe an average engineer gets much of a chance to do so unless he/she are working for the very specialized companies who do this specific type of design and fabrication. There are maybe 5 to 10 such credible or recognized companies in the North America. I say “recognized” because a lot of faith and confidence is put on their back to produce the specified and desired product. Sometimes, depending on circumstances, some design liability is involved – depending on contractual arrangements and terms. Therefore, the subject of “efficiency” is not discussed until one gets into a contract with such a company. Of course, if a purchaser is going to hold the designer’s feet to the fire, the price and contractual terms go up proportionately. After all, fair is fair.
Sooner or later particulate size comes into the picture when the term efficiency is employed in this type of separator. And that’s where the “problems” start. If you are linked or deeply immersed in the oil business, you must have had some contact with or own a copy of John Campbell’s two volumes: “Gas Conditioning and Processing”. If you haven’t read Volume I, I strongly recommend you do so, especially Chapter 8, “Process Vessel Specification”. Campbell deals with this subject in a manner that is more specific and practical than even the GPSA does – which is admirable. On separator sizing, John is very frank and direct: “Do not be naïve. Most published capacity curves are for ideal conditions. Use them cautiously.” He further adds: “It is almost impossible to measure particle sizes in plant service.” I certainly agree. He goes on to deal with the subject of efficiency in a general and unspecific manner. How can you talk of efficiency of particle removal when you can’t measure the particles? And even if you could, the particles of liquids continually change in diameter as they progress in a process line. It is a difficult subject for any practical engineer – except for an academician.
Two persons who claim to have measured and tabulated oil-gas separation are Dr. W.D. Monnery and Dr. W.Y. Svrcek (University of Calgary) in Canada. However, I believe they get the particle size “identified” by back-calculation, I think – not by actual measurement. I have a report on a series of tests done by them and I believe you can download it from the Internet. I don’t have any website identified, but you can try Google.
That’s as close to talking separator efficiency as I’ve been able to identify. I’m sorry if I can’t give you any more information. It’s not a very easy subject to talk about or much less to try to measure in the field.
Here is the link of the referenced article
http://www.ptac.org/env/dl/envf0112p.pdf
Art, thanks for the article references as I have been looking for some time to get some more clarity on this grey topic.
Krossview
Here is the link to the full document by Monnery and Svrcek.
www.ptac.org/env/dl/envp0102.doc
The authors do calculate the droplet size and compare it against known publications instead of measuring actual droplet size and efficiency.
Peerless Manufacturing has developed the Laser IsoKinetic Sample (LISP, which is capable of measuring the actual droplet size and separation efficieny in a separator. http://www.peerlessmfg.com/pdf/care_06LISP.pdf
Pall is another vendor who utilizes a Liquid Aerosol Separation Efficiency (LASE) to measure coalescer performance. http://www.pall.com/articles_chemical_5205.asp
The real removal efficiency remains a guessing game for a lot of separators currently in operation. Unless you deal with a reputable vendor like Art point out.
I trust these links are useful to spread the knowledge, that the technology is available to measure separation efficiency. Off course common sence and good engineering judgement still need to prevail to interpret the results.
Krossview
Thanks are due you not only from me, but from a host of people out there who have been struggling to identify separator performance for many years. Progress has been made in identifying a factor that has kept us in the dark for a long time and your research comes at a time when it can be of great help to a lot of us.
Thanks again.
