Basic Question to settle an arguement
Take a hydraulic press. If it takes a force of 1000kN to fully compress 1 object. What force is required to fully compress 2 objects if stacked in series (one on top of the other)?
Would be pleased to have your responses.
RE: Basic Question to settle an arguement
If two equal springs a stacked in series you can not compress one without compressing the other. The force is the same, the stroke doubles and power doubles.
If the two springs are in parallel the force doubles, the stroke is the same and power doubles.
The power is the same with the springs in series or parallel.
Barry1961
Work Double.
Power indeterminate from the information provided.
Can not know the power without knowing the time.
Barry1961
Picture this:
Take an egg. Place it on a concrete floor and stand on it. Wipe your foot clean.
Take a brick. Place it on the concrete floor and stand on it. When satisfied that everything that is going to happen has finished happening, remove your foot.
Now take a new egg. Place it on the concrete floor and gently balance the brick on top of it. Now stand on the brick. Will the brick protect the egg from your bodyweight?
Sometimes, changing the question to make any variables that don't need to be the same become very different makes it easier to picture what's going on.
A.
