Fill object help
Fill object help
Hi.
I'me trying to create some objects with diferent specifications each, and I've some (I'm sure) basic questions.
How can I define the line of a polygon (dot, dot-line, etc) in a block ?
How can I define the fill of the polygon ?
Can I define a block with a fill of squares (50cm x 50cm, for example) ? Like a mosaic floor of a house...
thanks in advance...
RE: Fill object help
"How can I define the line of a polygon (dot, dot-line, etc) in a block ?"
are you wanting to create a line type or just a block that contains a polygonal shaped object that is made up of dots
"How can I define the fill of the polygon ?"
what do you mean by fill are you talking about a hatch or what ?? please elaborate
and yes you can define a block that looks & represents a mosaic tile patern i have done something similar with a wood floor design
if everyone helps everybody the world will be a better place
- About the line type, I've already made it... :)
- About the fill, what I want to do is to create a block and make it opaque, so when I put it above other I don't see what's behind. I've managed to do this using the hatch, but when I print the drawing, the "opaque" block is filled whith colour (I've tried to fill the block with white, but when I print it, it turns gray...)... I'm sure that there's another way to do this..
- About the mosaic floor, how can I define that kind of block ? With the hatch ?
Thanks again...
