Deformation of flat plate with uniform thickness
Hi
I'm looking for a formula that will yield the maximum stress and deformation of a flat plate under uniform load.  I understand from a previous post that Pounder's plate theory is the way to go, but I do not have a copy of the text they reference.  Is it available on the net?
RE: Deformation of flat plate with uniform thickness
For circular and annular plates you'll find it in the site below (rectangular plates to come...).
prex
motori@xcalcsREMOVE.com
http://www.xcalcs.com
Online tools for structural design
Thank you.  Unfortunately I am looking for the rectangular plate formula.
Try "Roark's Formulas for Stress & Strain" - McGraw-Hill.
Two sources that I can think of:
- Roark's Book chapter 10  Table 26
- Mark's Standard Handbook for Mechanical Engineers 1978 edition page 5-52 & 5-53
If you don't have these resources post you details and I am sure someone will post an answer.  Rich
I think there is a Mathcad 2000 Pro sheet downloadable from the Collaboratory site. I can send it (Plate10b.mcd) to you, of if you can't make it operative, a .doc file to see the formulation at least. Post if so an e-mail address.
Thanks everyone, I have found a copy of the info and it is exactly what I needed.
