MAWP & Static Pressure
Regarding pressure vessels intended to be designed per ASME Code Section VIII, Division 1, I have seen calculations produced by various fabricators that included static pressure and some that do not. Which is correct?
S. Bush
www.water-eg.com
RE: MAWP & Static Pressure
In some cases, the loadings of UG-22 could be negligible in comparison to internal pressure.
The part on determining minimum wall thickness under internal pressure (UG-27) also requires the designer to take into account loadings from UG-22.
Steve Braune
Tank Industry Consultants
www.tankindustry.com
