Cavity feature ref' plane
Hi Ive created a cavity feature and saved it as a libpt. I found that when I drag and drop to insert the cavity feature it inserts on its side cutting a channel instead of a vertical hole. Now I know this is because the selected cavity feature reference plane is the wrong one so if I edit the feature how do I select the top of the cavity to become the correct insertion plane ive tried but it still seems to be using the first plane
RE: Cavity feature ref' plane
i am struggling with the same problem....have you found a solution yet?
