How do I create a concentric pattern??
Please help me.  I am a ProE user who is just learning SW and loving every minute.  What I am trying to do is trivial in Pro but I can't figure it out in SW.
What I'm trying to do is create a pattern of concentric annular thin cuts similar to growth rings on a tree or ripples in a pond.
Ideally I would like the rings to be segments of a circle.
Thanks in advance.
RE: How do I create a concentric pattern??
If you are serious, your addition to this forum is VERY welcome change ... but I think I just saw a pink animal with a snout & curly tail fly by my window.
You will probably be able to use the Vary Sketch option under the Insert > Pattern?Mirror > Linear Pattern function.
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
Sketch your rings on the face or plane that you want them.  Select extruded-cut.  In the property manager select the contour tool and highlight each ring.  Then go to thin feature and select your width and complete.
Quote (SW_"Whats_Wrong"):
Thin features cannot have more than one closed or open profile curve
BlimeyLimey,
Thanks for the file.  It was quite helpful, however, I have one more question.
I would like to have the controlling dimension be a diameter instead of a radius but the pattern dialog isn't happy with diameters.
Thanks a bunch
Would "vent" work for you? Insert > Fastening Features > Vent.
Flores
SW06 SP2.0
By "controlling dimension," do you mean the size of the original slot? If so, there are a couple of ways to do that;
1) By using the "mirror about a centreline" feature when placing the dimension.
2) By dimensioning a centreline which is constrained mid point to the origin.
See the configs in http://www.mooload.com/file.php?file=files/1132682482/Concentric+Rings.SLDPRT
