Brazilian Tensile Test
Could anyone comment on the engineering applications of Brazilian Tensile test? What is a significance of it?
RE: Brazilian Tensile Test
Could you describe or provide a reference to this test?
Jeff
Jeffrey T. Donville, PE
TTL Associates, Inc.
www.ttlassoc.com
Check out at the end of the FDOT Soils and Foundation Manual Appendix A downloaded at
http
Brazilian test is an indirect experimental method to measure the tensile strength of rock.
Because the strength of rocks is more pronounced in compression and shear, the tensile strength is less significant. However, tensile strength (along with the triaxial compression strength) can be used to obtain precisly the Mohr criterion of failure (cohesion and compression).
The tensile strength is also required when I do a numerical modelling of a case study in rock mechanics.
Check out:
http://hrcweb.nevada.edu/qa/IPR/IPR-010R1.pdf
http:
One other application is pull-out of anchors/bolts. Usually you neglect tension in cone pull-out to be conservative. Knowing the tension might help under some circumstances.
