Microstructures for:
Hi, is there anywhere on the net where I might find pictures of the microstructures of any/all of the following:
Cu/4%Sn, as-cast
Cu/4%Sn, annealed
Cu/37%Zn, as-cast
Cu/42%Zn, as-cast
Cu/4.5%P
Cu/8.4%P
Al/4%Cu, solution treated
Al/4%Cu, solution treated & over-aged
0.35%C steel, annealed
" , normalised
" , quenched
" , quenched and tempered.
Hopefully I'm not in the wrong forum here. Any help would be much appreciated. Thanks.
Cu/4%Sn, as-cast
Cu/4%Sn, annealed
Cu/37%Zn, as-cast
Cu/42%Zn, as-cast
Cu/4.5%P
Cu/8.4%P
" , normalised
" , quenched
RE: Microstructures for:
http://www
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
