Offsetting an Ellipse
Hey all,
I am using SW'05-SP 5.0. I am trying to offset an ellipse and it is not letting me do it. It gives me a tool tip which says "Only finite lines, arcs and splines, excluding fit splines and offset splines are eligible for offset".
I just want to know why I am not able to offset an ellipse. Any thoughts will be appreciated.
RE: Offsetting an Ellipse
Just guessing here, but ...
An offset of a line/arc/spline will be a line/arc/spline.
An offset of an ellipse will NOT be an ellipse.
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
My assumption is SW is buliding an Ellipse or a Parabola by using a "Fit Spline" method. But I am not sure.
I think the software should allow me to offset an ellipse since its closed and finite.
I beleive 2006 added the ability offset ellipses and parabolas.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2005 SP5.0 on WinXP SP2
SolidWorks 2006 SP1.0 on WinXP SP2
I seem to recall that problem can be overcome if you insert a split point or points. As mentioned, the offset of an ellipse is probably not an ellipse, so you have to make the curve a spline.
"or something like that"
Hardie "Crashj" Johnson
You can do this offset directly in 2006.  The offset is a spline.
In 2005 you will have to split the ellipse into 2 segments, fit spline and then offset the spline.
