Possible video card problem
Every so often I'll open a drawing or model and get a big black bar along the left and top of my viewport pane of Solidworks.  I'm using a HP xw8000, Xeon proc, 1.5GB Ram, Nvidia Quadro4 380XGL card.  The only thing is that the video driver I have is from HP NOT Nvidia or the one listed on SW certified driver list.  I would only assume that HP used the correct driver since I bought this PC designed specifically for SolidWorks from HP.
Any help?
"Perfection - a result of many mistakes."
BJH
RE: Possible video card problem
The obvious would be to download the nVidia driver and not assume HP gave you the right one...
http://www.nvidia.com/content/drivers/drivers.asp
Sorry if I'm missing something or that seemed rude...it's not meant to be (rude, that is).
I was also running Windows Media Player at the time.  And our IT guy found out that there is a conflict with WMP and SW.  So i'm trying not to run WMP.
BJH
Strange... I run WMP all the time with SW and have not had any conflicts.
How did he determine that it was a conflict?
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I'm with Scott......I run WMP with no problems to SWx.  You might be a victim of the Sony cloaking software if you're loaded songs from a Sony CD.....just a thought.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
