Large part mfg problem
Hi All !
I have a part that I am looking to produce a few thousand of. Sounds simple enough right ? Well, the part is almost 41 inches in diameter and has a volume of 465 cu in (almost 20 lbs). The has a little complexity and is a straight pull. I tried getting injection mold quotes, but was turned down everywhere I went (part is too heavy).
Any suggestions for maufacturing?
RE: Large part mfg problem
Mike
I do know a moulder who could injection mould it, but tooling costs would be enormous.
Any moulder who does automotive bumpers should have the capacity if not the will to do the project.
http://www.reln.com.au
They specialise in very large mouldings.
Australians are used to small runs, in fact we might be considered the worlds small run specialist nation with a high degree of physical seperation from other markets and a home market of 20,000,000 people.
They have presses with up to 25 pound shot, structural foam, gas assist, and injection molding, just what you might need for that size of part.
It may not be, the company I work for, mould parts that are in two or three sections, each part moulded individually and assembled inside each other then moulded over again, a typical example of this is our revolutionary made Hospital Vacuum Pump, which we designed and export worldwide.
Saying that though, you may be right - I'm sure you have researched all avenues, but as a previous poster has suggested (differcult to say without a drawing)
