High-accuracy leveling and alignment
Hello
I want to level and align a number of sub-modules very accurately.  Complete machine length is around 5m (16 feet)
Is anybody aware of commercially available laser systems?
What about other methods?
Many thanks
Dave
RE: High-accuracy leveling and alignment
How accurately and what mechanical/optical references are available?
TTFN
Hallo IRstuff.
Accuracy in the region of 0.05mm or better
The datums of the large metal panels will be H7 holes, and into these I want to assemble posts for the lasers to align/work etc.
As the panels are taller than they are wider, I want to level the panels using datum holes which are vertical - a sort of laser plumb-line I guess!  I will align (vertically) all the modules using the lower datum hole in each panel.
Do I need to send a sketch?
Cheers
Dave
Hamar has a system that I have used. The one I used came over on the mayflower and still was accurate to .0001".
www.hamarlaser.com
Nick
"Speed costs money boys, how fast do you want to go?"
Hi DDRSS10 - guess that menas something to you smile
Greetings from Belgium, and thanks for your valuable post.  As per usual, the answer to everything appears to be on the net.
I checked out the website, and the hamar products seems very appropriate.  Out of interest, what were you levelling?
Thanks - or 'bedankt' as they say in Belgium
Dave
Dave,
Greetings from Minnesota, U.S.A. "Came over on the mayflower" refers to the age of the tool, just a little joke. We were leveling a 2.4m sq platten full of bolsters for the asembly of some tight tolerance frames. The leveling of the laser is very important before starting any measuring. Take your time and you will find that it works flawlessly. Good luck, give some updates on your progress.
Nick
