wiring single phase motor with for/rev switch
Hi Im trying to wire up a single phase motor using to contactors and a start/stop/forward/reverse switch that has to be latched (sealin) my question is where do I connect the following wires into contactors to create this function here are my wire numbers: P1, P2, T2, T3, T4, T5, T8. would really appreicate this help
thanks
RE: wiring single phase motor with for/rev switch
Hello HVACNEWGUY,
The wires P1 and P2 are the thermal protector.
You have a Dual Voltage Single Phase Motor the T1-T2-T3 and T4 are the Main Winding(Run) and T8 & T5 The auxiliary winding (Start).The first to do is choice the voltage(High or Low) and the connections are:
Voltage    Rotation    L1    L2    Join
High        CCW            1    4,5    2-3-8
        CW            1    4,8    2-3-5
Low        CCW           1,3,8    2,4,5    ----
        CW           1,3,5    2,4,8    ----
The direction of shaft rotation can be determined by facing end of the opposite the drive.
You could use a drum switch to perform the foward and reverse .
Petronila
Hi Petronila
While pondering your excellent answer I wondered how you had this knowledge so did a search on google and found a reference to print and keep in my notebook. I work with both US and Euro motors and have been fortunate enough to get info with or on motors.
http://www.patchn.com/motor_connections.htm
machmech,
One of the best references for motor information that I have come across is the Brook Hansen 'Little Red Book'. It is, or was, available from the manufacturer for a nominal cost. I hope they are still publishing it and it isn't yet another casualty of closing the Guiseley and Huddersfield manufacturing works' and shifting production to Poland. Quality was the first casualty, should anyone be wondering.
 I can no longer find it listed on their website. You might ring them up and enquire if it is still available.
http://www.brookcrompton.com/pages/contacts2.asp?area=uk&image2.x=26&image2.y=8
One day my ship will come in.
But with my luck, I'll be at the airport!
