where to find AASHTO traffic loads?
Hello.
I would like to find information on vehicular traffic loads as they pertain to live load surcharges over an MSE wall which is to be designed.
Which AASHTO manual should I look in?
Specifically, I need to know what surcharge I should design for HEAVY FORKLIFTs. The kind of fork truck that loads 30 Ft. boats into storage racks.
here is a good example of the fork truck I will have working on a retained parking lot: http://www.marinetravelift.com/m2000.aspx
Ground bearing pressure is listed at 95 psi. Maximum combined weight of the vehicle and boat could reach 84,000 pounds!
thanks for any help you can provide.
___
Craig T. Bailey, PE
www.bailey-associates.com
RE: where to find AASHTO traffic loads?
The AASHTO Bridge specs incorporate FHWA NHI-00-043 (Design and Construction of MSE Walls and Reinforced Soil Slopes) by reference. This file can be downloaded free from www.fhwa.dot.gov/bridge/geopub.htm
As for the surcharge load, you seem to have a good idea of the actual live load. You could measure and model the actual "point" loads from all four wheels associated with the forklift using Boussinesq or Westergaard theory and compute an "equivalent" uniform surcharge to use in the MSE analyses. I think that at a minimum, you should use a 250 psf live load surcharge, but your equivalent surcharge (one of those engineering judgement things, I suspect) would likely be much higher.
BigH makes a good point that depending on the height of your wall and the allowable bearing capacity of the foundation soils, you may want to use something other than MSE.
Hope this was helpful,
Jeff
Jeffrey T. Donville, PE
TTL Associates, Inc.
www.ttlassoc.com
ciao
To elaborate on BigH's discussion, what you end up with is a block of the foamed concrete. During the pour, metal strips are embedded in the exterior face of the elastizell so that precast panels can be attached later for the look of a MSE structure. For analysis purposes, however, it's just a big block of lightweight foamed concrete.
Hope this wasn't confusing.
Jeff
www.ttlassoc.com
As far as Elastizell goes, I will look into that. Jeff, you mentioned that this material utilizes strips for facing only. No reinforcement at all?
A reply asked if the 95 psi was correct. I do not know, that is what the equipment manufacturer lists as tire contact pressure for air tires. This machine can be equipped with solid tires. Yikes, that ground pressure would be disturbingly high!
This wall will require some additional bearing capacity tests, that I am sure of. Especially since the foot of the wall will include a downslope.
___
Craig T. Bailey, PE
Elastizell sells foamed concrete with a designed unit weight and strength. You pick the weight range and they will tell you what range of strengths they can give you (or vice versa).
The material, as I understand it, is batched on-site and poured in lifts of several inches at a time.
To replicate the look of MSE walls, they embed metal strips in the pour. The metal strips are only used to affix a precast facing panel.
In the end, you end up with an essentially monolithic block of very lightweight unreinforced concrete. Which only looks like MSE from the front of the wall.
Clear?
Jeff
www.ttlassoc.com
