Gettting text larger than 72 points
Solidworks 2005
want to place and cut text into surface but need text larger than 72 points.
Tried using tools/sketch tools/ scale , but the scale doesn't make the text get any bigger.
How can I make larger text?
RE: Gettting text larger than 72 points
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
When placing the text, deselect Use document font, then click on Font, then just type in the size (Units or Points) that you want.
For text that is already placed, open the sketch, double click the text then continue as per above.
