Best callout for pinning to shaft together?
I have a hollow shaft and a solid shaft that I want to pin together. I'm looking for GD&T callout that will make sure that the pin hole will be drill thru center of both dia's. So went I go to pin the part together the hole's will be in-line with each other.
RE: Best callout for pinning to shaft together?
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
