Chamfer or Fillet a portion of an edge
Is there a way to abruptly terminate a chamfer or fillet at some position along an edge? I have been splitting the part into two bodies chamfer the edge of one of them, and then combine the bodies back together. This works, but seems to be the hard way...and in some cases I can't split the part because previous features fail.
tom..
tom..
RE: Chamfer or Fillet a portion of an edge
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
All, uncheck tangent propogation and select the edges manually.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2005 SP5.0 on WinXP SP2
SolidWorks 2006 SP1.0 on WinXP SP2
htt
Click the link above, Here is a simple pic of a chamfer along an edge but stops short at some point. I did this by splitting the body in two, and then chamfering one of them then combining them back together. I was hoping for an easier way.
Thanks MadMango, I have done what you suggest also
tom..
You also do a split line on the face to get two edges, then chamfer the edge.
Jason
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
tom..
Flores
SW06 SP1.0
Find the technique in the blending fillets tutorial here
http:/
You can adapt this method to all kinds of stuff, such as damming or stopping you fillet or chamfer.
RFUS
1) create a plane at opposite angle from chamfer angle along the edge to be chamfered and from adjacent plane (in the case of the example I used the front plane and created a 135-deg plane for a 45-degree chamfer)
2) cut-extrude - sketch a rectangle, specify length of chamfer, add radius at end(s) of cut.
[URL=http://imageshack.us][IMG]http:/
[URL=http://imageshack.us][IMG]http://img
